P0410 secondary air injection system malfunction
Old 01-04-2012, 11:49 AM
Dsteven21's Avatar
Default P0410 secondary air injection system malfunction
just bought a 2001 formula red s2000 with cel light on. I took it to autozone and they said it was the P0410 secondary air injection system malfunction, Any ideas how to fix it?
Old 01-04-2012, 12:00 PM
Billman250's Avatar
Received 1,275 Likes on 778 Posts
Make sure it is not P0411, this is most common.
A P0410 could be a bad air pump or pump relay. P0410 is an electrical issue with the air pump, located under the drivers side headlight behind the bumper.
Old 01-04-2012, 12:23 PM
Dsteven21's Avatar
actually it was P0411, looking to see if i can fix it myself? any help on step by step instructions?
Old 01-04-2012, 12:27 PM
1nate7's Avatar
https://www.s2ki.com/s2000/topic/902...mp-delete-kit/
Old 01-04-2012, 12:28 PM
Billman250's Avatar
Thought so
Vac lines for the air pump are the most likely cause. They are on top of the engineeasy to get to. Routing and direction of the little white check valve must be exact. Check here.
Old 01-04-2012, 12:44 PM
Dsteven21's Avatar
thanks guys ill see what i can do if i cant fix it myself, do u know anywhere in jersey that can fix it for me?
Old 01-04-2012, 12:47 PM
Billman250's Avatar
Minitoyota or s~factor are in jersey. It's just vac lines man fix it up
Old 01-21-2012, 12:24 PM
Dsteven21's Avatar
/Users/Dsteven21/Desktop/2012-01-21_15-53-14_640.jpg the top line was not plugged in do you think the CEl will go away now?
Old 01-21-2012, 02:09 PM
Billman250's Avatar
yes it will go away after the monitor cycle is complete. Will take a cold morning start at the least.
Or you can pull the "back-up" fuse under the dash for 10 seconds.
Old 01-22-2012, 10:17 AM
Dsteven21's Avatar
i pulled the back up fuse and it went away, how long will it take to come back if problem is not fixed?
Quick Reply: P0410 secondary air injection system malfunction
