P0411
Old Nov 25, 2007 | 10:20 AM
CFactor's Avatar
Default P0411
So I know this CEL code has been posted a million times, but I am not getting the code after installed a CAI. I have the factory intake and it came on one day after I was about to install my cheap EBAY CAI (which I decided not to install seeing it was a POS).
I took the factory airbox setup out and five minutes later reinstalled it the exact same way it was taken out. The next day (once the car had a cold start) the CEL came on.
The secondary air pump still starts, sounds normal, and runs for about 8 seconds then cuts off. I am just trying to figure out how to troubleshoot it with the stock airbox setup, bc my honda dealership is absolutely worthless.
Old Nov 25, 2007 | 10:41 AM
negcamber's Avatar
Check the vacuum lines again.
https://www.s2ki.com/forums/index.php?showtopic=105368
Make sure they are not reversed.
Old Nov 25, 2007 | 02:33 PM
importkid's Avatar
When I did mine one of the lines under the intake manifold came off and it was kinda a bugger to see. I'm sure you already have, but double or triple check all the lines connections.
3318S2K
Jun 2, 2018 12:43 PM
Inteligentleman
Aug 23, 2016 11:03 AM
s2000BB
Mar 1, 2014 10:00 AM
IntenseImports
Aug 9, 2008 05:30 PM
phillys2k
Jun 5, 2006 10:32 AM
