P0411 code. Help!
Old May 12, 2011 | 03:26 AM
  #31
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
How do I post a photo from my s2ki album? If someone can post how to do so i'll post how to fix your P0411
Old May 12, 2011 | 01:11 PM
  #32
slowpokeS2K's Avatar
all i did was right clicked on image, select "copy image location", then insert in post with img
if thats your pup, you have one great looking dog there...
Old May 17, 2011 | 11:14 AM
  #33
hmm. im not sure whats going. s2ki needs to make it easier to post up images from the gallery
EDIT: i see your problem, your copying the page link and not the actual image link. if you take a look at your pictures, there should be a share button at the top right and under that option you should see image link.
Old May 17, 2011 | 02:34 PM
  #34
Billman250's Avatar
Top Answer: 1
Old May 17, 2011 | 02:35 PM
  #35
Billman250's Avatar
Top Answer: 1
What a pain. Thanks man. i really hate the new site. Linking pics with the old site was so easy.
Old May 17, 2011 | 03:27 PM
  #36
now can these pipes be just placed on or do i have to clamp them down with a ziptie or clamp? also, i noticed that the part labeled 1 in the picture has probably never been replaced. would that cause the CEL to pop up if its clogged?
Old May 17, 2011 | 04:59 PM
  #37
Billman250's Avatar
Top Answer: 1
no clamps needed. you part number one is likely not clogged. It is a check valve.
Old May 19, 2011 | 01:12 AM
  #38
s20009k's Avatar
Can someone explain what the pictures above mean. what are you suppose to do?
Old May 19, 2011 | 01:54 AM
  #39
dagle's Avatar
well, you see they are considered man's best friend for their loyalty. What you use them for or what you train them to do ultimately decides what they mean and what you're supposed to do with them. Personally I would raise it as a friend of mine as well as a security system for the house.
for the other diagram, it's the components of the air pump system so you can see the air plumbing and all the components in play.
Old May 19, 2011 | 04:43 AM
  #40
JohnsS2000's Avatar
