P0411/P1399 / check engine blinking
Originally Posted by roscoe,Jan 16 2011, 06:37 PM
he said he did drop gear when the car started to decrease its speed but noticed it wouldnt accelerate or pick up any speed
the rpms hit the rev max and the car slows down,
then the valves and stuff get messed up, sounds like over rev to the max and he just doesnt know what it is
park and get honda to look at it D:
ps. feed back!!! i wana know what happened (:
Originally Posted by s2cho,Jan 17 2011, 11:16 PM
over rev is when your going like 70 in 6th gear and you drop it to 2nd and
i will update you guys on what happens
P0132 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit High Voltage
P0500 Vehicle Speed Sensor (VSS) Circuit Malfunction
P1259 VTEC System Malfunction
P0411 Secondary Air Injection System Incorrect Flow
P0301 No. 1 Cylinder Misfire
P0302 No. 2 Cylinder Misfire
P0304 No. 4 Cylinder Misfire
P0453 Fuel Tank Pressure (FTP) Sensor Circuit High Voltage
P0451 Fuel Tank Pressure (FTP) Sensor Range/Performance Problem
P0300 Random Misfire
I couldn't find a P1399 code explanation
Man he fried something wish I knew what maybe a shorted harness or fried circuit board I really don't know I'll refer billman to this thread so he can scratch his head
Originally Posted by EastS2k,Jan 18 2011, 06:42 PM
Sounds like you have a lot of trust in him... but from what you are describing it sounds like an over rev, he probably went WOT in 4th and shifted in to 3rd.
