Painting calipers
Old Apr 6, 2009 | 09:59 AM
S2KRAY's Avatar
Active Streak: 30 Days
Top Answer: 1
Default Painting calipers
I got some new wheels which are an open design and now my painted calipers really show up which is what I wanted. I am going to be cleaning and repainting them and I notice the metal area just below the rotors extending to the area the wheel mounts to is rusted and doesnt look great. I was wondering if I could carefully remove the rust, clean it with solvent and paint the area flat black with Rust Oleum. I can do it before I repaint the calipers with 2 coats of Rust Oleum. Do you think I need to prime the area too. I think it would look better than leaving it unpainted. Thanks.
Old Apr 6, 2009 | 05:55 PM
Nside's Avatar
i tried painting that portion of my rotors several years back - i used silver VHT high-temperature paint. in the end, the paint turned out silver-ish / blue and the rust came back within a couple months.
black paint might work better. my plan is to buy new rotors (something like http://www.propartsusa.com/product_info.ph...ducts_id=10221).
Dan
Old Apr 7, 2009 | 10:46 AM
S2KRAY's Avatar
Top Answer: 1
Do you think I will need to apply high temp paint or will the Rust Oleum suffice.
Old Apr 8, 2009 | 02:42 PM
Nside's Avatar
i'm not too sure, depends on how you drive / if you track your car. high temp definitely can't hurt!
Old Apr 8, 2009 | 04:22 PM
S2KRAY's Avatar
Top Answer: 1
I dont track it but I still think hi temp makes sense. Thanks.
Old Apr 8, 2009 | 04:56 PM
HS2K007's Avatar
use high temp, brakes get hot. most auto parts store sell paint designed for calipers
Old Apr 9, 2009 | 03:58 PM
S2KRAY's Avatar
Top Answer: 1
Ok, thanks.
Old Jan 5, 2010 | 01:39 PM
HiVolume's Avatar
You can also sandblast the calipers, but you need to make sure you don't blast the pistons. VHT caliper paint works great. They have a spray type, as well as a regular paintbrush type. I don't think buying new calipers is necessary...
Old Jan 5, 2010 | 01:46 PM
dfvs2k's Avatar
All brake caliper paints are high temp. All other will flake and peel within 6mth to a yr.
wasupdu
Aug 3, 2006 06:49 PM
RO323
May 22, 2006 09:22 PM
Portland
Jul 10, 2003 03:41 AM
tenblade2001
Jun 11, 2003 12:59 PM
Big Al
Nov 12, 2001 06:03 PM
