Parking light problems
Old Oct 3, 2007 | 04:47 PM
daktruckie99's Avatar
Default Parking light problems
Well both parking lights worked fine when I parked the car on Monday. Went to take the car out today and now they aren't working.
The bulbs were removed to remove the headlights but that's it. When they were hanging from the harness they worked because when I locked the car they flashed, but today when re-installing the lights they were dead.
I looked in the service manual and the fuse they are on is shared with lots of other lighting which is working fine. Is it just bad luck and they both went at once?
1) Any way to check the bulbs without removing the lights again?
2) Is there another fuse I have missed here?
Thanks in advance
-Mike
Old Oct 3, 2007 | 05:53 PM
modifry's Avatar
Honorary Member
You're right, they are on the same circuit as a ton of other lights, plus they are on separate grounds, each of which has many other circuits that would be noticed if they didn't work.
I'd say either both bulbs went out or perhaps you didn't quite "lock" them in place and they came loose?
Old Oct 3, 2007 | 05:56 PM
Guess they're coming off on friday since I don't have to work.
Thanks Bob!
2000BBS2k
16
Apr 28, 2014 12:03 AM
bbss2k
Jan 25, 2012 05:25 AM
type-j
May 23, 2009 06:47 AM
Norby
Aug 21, 2006 10:27 AM
TheCarGuy2021
Mar 25, 2006 05:57 PM
