Part # for the that rear axle Nut
First I did search I promise.
What is the part number of the nut that holds the hob on the rear axle? It is the one that clicks if it is not torqued down to 230 ft/lbs.
I cant seem to identify it in any of the drawings.
Thanks
Thanks
https://www.s2ki.com/s2000/topic/929...e-nut-tsb-diy/
Its 180 lbsft then another 60 degrees.
darcy
Ran across this thread searching for the part number, so updating it for posterity. Part number is actually: 90305-SD4-003
- SKU:90305-SD4-003
- Other Names:Nut Spindle (24MM)
- Replaces:90305-SD4-010, 90305-SF1-000
solitarycheese
May 26, 2017 11:10 AM
