Passed Emissions Test
I figured S2k's could pass smog with a test pipe...back in high school when I had an Eclipse GST...all kinds of stuff on it, injectors, fuel pump, type of engine management, 3" turbo back, b16g turbo, etc. and no cat...I was still able to pass smog #'s wise on the machine...
My S2k runs much cleaner than that GST did
Originally Posted by fperra,Aug 18 2005, 01:59 PM
Doesn't necessarily make it bad for the environment either.
Most likely they didn't actually put it on the sniffer, alot of times it's just an OBDII check.
Extremely unlikely that an s2k pass a modern tailpipe test without a cat. the NO would be too high.
Originally Posted by WVtwisties,Aug 18 2005, 02:43 PM
yeah...him passing wouldn't even be noteworthy if it weren't bad for the environment
Good/bad for the enviroment is all relative. The more you drive the worse you are for the environment. Removing the cat just increases the scale. However if it is a low use car then you can't really make the claim that you're hurting the environment more than the guy driving his SUV 50miles a day.
