Passenger Side Door Lock
Old Jul 3, 2009 | 01:41 PM
BallSackJack's Avatar
Default Passenger Side Door Lock
I recently put some key hole covers in and I don't know whether it is just a coincidence, but immediately after (within 2 minutes) my remote no longer locked or unlocked the passenger side door. I can hear it try to lock/unlock but is not successful. I removed the key hole cover on that door but it didn't help.
I can't imagine how something so simple could affect the door lock, but maybe? Any ideas? My remote has always worked fine until now.
Old Jul 3, 2009 | 05:40 PM
JS2k.com's Avatar
Sponsor
Please keep me informed with what happens. While I don't think the keyhole covers are the cause, I'm willing to help out with the situation.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Jul 3, 2009 | 05:45 PM
zdave87's Avatar
Member
How are you remotely unlocking the doors? Standing outside the car-or pressing the 'unlock' button while the key is in the ignition?
Old Jul 3, 2009 | 06:01 PM
lols2000's Avatar
It takes two presses of the unlock button to unlock the passenger side.
Old Jul 3, 2009 | 07:10 PM
I'm outside the car and the key is not in the ignition and I'm pressing the unlock button dozens of times. Two presses has worked for the last 14 months of owning the car and was working today, but now it stopped
I don't believe the keyhole covers to be the problem in anyway, just happened right after I put them on
Old Jul 3, 2009 | 09:04 PM
CKit's Avatar
Have you tried manually unlocking and locking the door a few times? Both from the inside and also using the key?
Then try again with the remote.
Old Jul 3, 2009 | 09:19 PM
Thanks for the advice Ckit, I did that a few hours ago when I first discovered this problem and it didn't seem to help. However, I went out a few hours later and it unlocked after 2 clicks of the remote(only the first time), but then it wouldn't lock or unlock again (with the remote). I'd lock the car, but the passenger side wouldn't lock, even after several clicks and beeps from the horn.
Old Jul 3, 2009 | 09:30 PM
CKit's Avatar
Can you hear the passenger door clicking when you hit the remote?
I can't recall, is it possible to "remote lock" the doors with the doors open?
Trying to sort out if it's a mechanical (rusted tumbler or lock mechanism) or electric problem (door open plunger, connection, actuator, etc).
I suppose it wouldn't hurt anything to put a little WD-40 in the keyhole.
Old Jul 4, 2009 | 12:50 AM
foxy_s2k's Avatar
From the symptoms described so far, my moneys on the actuator.
Old Jul 4, 2009 | 08:16 AM
I went out this morning and it worked the first two times of using the remote then stopped. I followed CKit's advice on spraying some WD-40 in the keyhole and it worked! I don't know if it's just a temporary fix, but now it's working everytime. Thanks guys
hondax2000
Oct 13, 2011 12:50 PM
PENROD
Tampa
16
Apr 16, 2009 12:24 PM
milomika
May 17, 2008 03:03 AM
Saki GT
Mar 30, 2006 12:30 PM
