Passenger window
Old May 5, 2024 | 11:42 AM
Dibsen's Avatar
Default Passenger window
Passenger window decided to stop working today.
was fine yesterday. Neither drivers side or passenger switch will get it to move.
I’ll pull the door apart when I get home.
any thoughts?
Old May 5, 2024 | 12:03 PM
Dibsen's Avatar
Ef me!
I hope this isn’t the case…
Maybe something just came loose
Old May 5, 2024 | 01:10 PM
windhund116's Avatar
any thoughts?
This switch is not OFF is it?
Old May 5, 2024 | 01:13 PM
Dibsen's Avatar
hmm…
Old May 5, 2024 | 01:17 PM
Dibsen's Avatar
My wife might have hooked me up when she was helping to bleed the brakes.
At least I got to look around in the door. Been meaning to do that anyway.
At least that was a cheap fix. Little embarrassing but cheap
Old May 5, 2024 | 01:47 PM
bad_driver's Avatar
LMAO, had a freak out like a month ago doing EXACTLY this until I read about the lock switch.
Old May 5, 2024 | 01:53 PM
Chuck S's Avatar
This has probably happened to more us than will admit it.
-- Chuck
Old May 5, 2024 | 02:30 PM
Car Analogy's Avatar
Its easy to miss, because you'd assume the switch only disables passenger side.
Old May 6, 2024 | 12:43 PM
Slowcrash_101's Avatar
I'm rebuilding my regulator as we speak. Pro tip buy the $75 kit from Ebay, not the $100 one, the $100 one sucks, the ends of the cables don't fit into the window carriage, or into the spool properly. On the bright side, I've gotten quite good at taking off the window and regulator. It's actually pretty easy, just make sure you wear gloves, that door is super sharp.
Old May 6, 2024 | 01:02 PM
NoDelta's Avatar
I have 100% come to this site with the same problem. Just the switch shown above for me too.
Why in the world does this disable the driver side control?!
