Passenger window problem
Old Mar 4, 2009 | 07:32 AM
Freshjive's Avatar
Default Passenger window problem
Problem:
Passenger window will not go down with the switch, but It will go down when I drop the top, and use the drivers side located, passenger window switch.
Things I have tried to fix it with:
-got a new switch
-made sure the passenger window lock was not on (located on the drivers door)
-checked all the fuses
Any ideas what could be the problem?
thanks,
Matt
Old Mar 4, 2009 | 08:10 AM
Sideways's Avatar
Did you hit the lock out switch on the driver door panel?
Did you read the manual?
Check it out.
Old Mar 4, 2009 | 09:48 AM
Freshjive's Avatar
Hey I did thanks,
I should also note, when the lockout switch it engaged both side windows do not work, and when its not engaged i can control both windows from the drivers side
Old Mar 4, 2009 | 11:48 AM
fltsfshr's Avatar
Matt did you get a new passenger switch or drivers side. The drivers side has a control unit built into it.
Find a helms manual under power window you'll find some continuity tests that will track down your problem. You can probably view it online.
fltsfshr
Old Mar 4, 2009 | 12:07 PM
daktruckie99's Avatar
Will it go up?
Old Mar 4, 2009 | 12:18 PM
Freshjive's Avatar
I replaced the passenger switch, I was not aware the control unit was built into the drivers side switch, I will take a look at that tonight and update tomorrow.
The window will not go up or down using the passenger side switch, If I use the driver side it functions normally
Old Mar 4, 2009 | 12:57 PM
speedworksracing's Avatar
Yea I would say replace the drivers switch. If it is not working correctly then I would do that.
sexysilvers2000
Sep 4, 2018 04:01 PM
WhiteLite
Feb 6, 2014 03:30 PM
S2K2226
Jul 30, 2013 06:45 PM
JohnnieChoi
Sep 3, 2012 01:46 PM
rai
Dec 12, 2005 02:25 PM
