Passenger window won't go up
My passenger side window is stuck down. When I push the switch down on the passenger side, I hear a click but the other way doesn't make a click. I don't hear any clicks when I try to use the driver side controls. how do I tackle this problem?
Step 1. Make sure you didn't turn off the passenger window switch. Tbere is a switch on drivers side door panel that completely disables passenger window.
Oddly, this switch not only disables window switch on the passenger side (so a child, animal, or abductee can't operate the window), it also disables the drivers switch for the passenger side (so driver can't ooerate it either).
Unfortunately, that isn't the case lol. To give more information, I went in the S2k manual and connected the pos and negative, and the motor was able to put the window up just fine. It's just when I use either switches on the doors, it doesn't work.
yes, it works quite well. so i went to go look at (below quote)
I figured this might have been a problem. I took both driver-side and passenger-side door panels off, and saw which switch was causing problems. I unplugged the passenger switch, but left the driver-side switch controls plugged in and it stopped going down on its own. Unfortunately, the driver-side switches were also screwed up. Passenger window going down stopped being a problem, now I just can't raise the window (no click for raising window). I went to ebay and bought replacement switches for both sides, and I'll see how it fares when they arrive by the end of the week.
