Pcv
Old Oct 1, 2015 | 12:49 AM
geekyjerry's Avatar
Default Pcv
Hello folks. I am going to be routing my PCV to my exhaust. (FI ~500whp ). Does anyone have any experience with it? Yay or nay?
Thank you all.
Old Oct 1, 2015 | 02:55 AM
Slowcrash_101's Avatar
Does your exhaust create vacuum to help relieve crank case pressure like the intake manifold can?
Old Oct 1, 2015 | 07:25 AM
Car Analogy's Avatar
Exhaust is opposite of intake. Intake creates vacuum, exhaust generates pressure. (A four cycle engine is basically an air pump.)
Is routing pcv to exhaust a thing? Wondering how that could work...
Sent from my SM-G920P using IB AutoGroup
Old Oct 1, 2015 | 10:33 AM
rrounds's Avatar
It works great "IF" you don't use mufflers. Been around over 50 years, all you need is a oil separator(don't want to suck all your oil out) a backfire valve and some high temp hose.
Here you go
http://www.jegs.com/i/Moroso/710/25900/10002/-1
See where it says "Cannot be used with mufflers" Mufflers no matter how good they flow, create backpressure.
ROD
Old Oct 1, 2015 | 06:09 PM
jkelley's Avatar
I cant imagine a PCV discharging to the exhaust... you would basically be saturating your cat and piping and such with unburned oil. It may even be an unsafe scenario.
Old Oct 4, 2015 | 01:48 PM
geekyjerry's Avatar
Here you go
ROD
Thank you! That's exactly what I am talking about. Do you see any benefit from this? I'm going 3inch all the way back.
Soviet
Sep 20, 2016 08:54 AM
jace44
Feb 13, 2012 01:56 PM
jyeung528
Mar 19, 2011 10:35 PM
tron1
Feb 13, 2004 04:26 AM
