Please Delete!
Ok here's the deal, I've looked through the search and didn't find enough concrete info to help fix my problem.
I have a rubbing, sometimes squeeking noise coming from the driver's rear wheel. I have had the wheel bearing replaced not too long ago, because it was almost making the same noise, but constantly all the time. It fixed the problem, but now I made sure the axle nuts were torqued down, and the brake pads have been replaced, but now i'm getting this sound of rubbing only when I apply the brakes. The rubbing is there basically less that 5 mph when I come to a stop. I have greased the sliders with grease that goes up to 400 degrees and the problem went away for a few days, but then came back. The weird thing is that the rubbing noise at less than 5mph doesn't happen when i go in reverse. If anybody has any ideas, let me know. Thanks.
