please help
Old Mar 31, 2008 | 10:22 PM
monsoon monster's Avatar
Default please help
ok i put my CAI on and my engine light is on i pulled out the back up fuse from the fuse box and it took it away for a couple of hours and i also disconnected the battery and when i got off work (8 hours later) its on again what else can i do to prevent the check engine light from coming on. it comes on from time to time.
should i jus leave it on until my car is used to the intake and it will come off?
what should i do?
please help
Old Mar 31, 2008 | 11:54 PM
smirfs2k05's Avatar
what should i do?
please help
Check to see if you routed your vacuum lines correctly.
Old Apr 1, 2008 | 04:03 AM
S2KVITO's Avatar
Vac lines are wrong... search for the diagram
Old Apr 1, 2008 | 06:30 PM
fasttech's Avatar
improper installation!! check hoses and clamps make sure all secure, wires pinched???left anything unplugged??
Old Apr 1, 2008 | 10:10 PM
i double checked everything everything fine. i followed instuctions and everything the vac line are properly installed all the line every thing. this weekend ima take it out and install it again and go slow.
Old Apr 2, 2008 | 05:46 AM
icemans2k02's Avatar
look at the box on the brace in front of the engine, make sure that on the left side that hose is going to your intake, on the other side of the box the hose should be routing back towards the engine. Take pics if possible oh and make sure the vacuum sensor that is mounted on the intake dosent have any shreaded wires or is clamped
Old Apr 2, 2008 | 10:29 AM
fasttech's Avatar
try installing factory airbox back in see if prob goes away
Old Apr 2, 2008 | 11:31 AM
Kyushin's Avatar
Banned
well pull the code, im sure it will be secondary air injection system = vavuum line
Old Apr 2, 2008 | 11:57 AM
thanks alot guys. i got the problem solved i hope its no comin on well see by the end of the day. it was the vacuum line its was backwards.haha i feel stupid now. jus hopefully that was the problem well see how it goes today.
much appreciated!!!
socal28
Apr 5, 2018 09:43 PM
aurora720
Sep 9, 2008 01:04 PM
Slacker80
Mar 19, 2004 05:57 AM
ConeKiller
Feb 28, 2003 01:46 PM
jays2000
May 28, 2002 09:21 PM
