Pluggin the oil squiters?
Old Jun 2, 2006 | 01:32 PM
wannabuy's Avatar
Default Pluggin the oil squiters?
Just curious on this one. I know that a lot of people plug the oil squirters on the pistons on B-sereies motors. With any of you that have built your motor have you plugged them or not. I figure not based on the design differences but with the motor coming together in a few weeks I wanted to ask the question for this is the first F-series motor for me.
Thanks
chris
Old Jun 2, 2006 | 01:46 PM
Asura's Avatar
What is ERL's opinion on this?
Old Jun 2, 2006 | 03:15 PM
Slows2k's Avatar
I wouldn't block the oil jets on any Honda engine, just for the piston cooling you will be loosing. Long term reliablity is pretty important to me.
The only folks I know not using oil jets is Inline pro, due to lack of clearance with the 2.5L crankshaft.
Old Jun 2, 2006 | 03:26 PM
s2kBryan916's Avatar
Why would you?
Old Jun 2, 2006 | 04:06 PM
Slows2k's Avatar
Blocking the oil jets reduces the oil mist in the crankcase the crankshaft has to cut through. On a drag application where the engine is only stressed for a few seconds of WOT, it not an issue.
My car see's plenty of WOT, closed throttle, back to WOT, engine braking and other road course/ street driving. Cooling the pistons with the oil jets is pretty important to me.
A few HP can be gained by limiting the windage losses.
Restricting Small Block Chevy lifter galleries has a similar effect.
Old Jun 2, 2006 | 05:44 PM
wannabuy's Avatar
I am waiting for Saen at ERL to return tuesday to gain his opinion. I figured before the motor goes together it would be good to check this out. There is so many ways of doing this in the Honda world I wanted to get user opinions so when I get to talk with Full-Race and ERL I can make a sound choice in the matter. Thanks for the input.
Old Jun 3, 2006 | 10:21 AM
GDM S2K's Avatar
I have mine blocked shut. When you sleeve a block its pretty much standard
Old Jun 3, 2006 | 11:03 AM
wannabuy's Avatar
Ah good we have someone that has done it. Thanks for posting.
-Chris
Old Jun 3, 2006 | 03:05 PM
Slows2k's Avatar
Iv'e got an 87mm bore AEBS sleeved block that still has them installed, I wouldn't call blocking the oil jets required for sleeving.
Old Jun 3, 2006 | 03:53 PM
ya@inlinepro's Avatar
actually
we CAN use oil squirters with the 2.5L. We just don't like using them. We have never used them in any of our motor builds
