Possible clutch problem please help!
Old Apr 7, 2008 | 06:13 AM
Zeeb's Avatar
Default Possible clutch problem please help!
Ok so someone help me with this. What do you think it can be. Normally when you put your clutch in it goes in about 1-2 inch's then engages and the engage part is like 4-5 inch's then the pedal is all the way to the floor, well this morning on my drive to work, the whole way, my medal would be soft and loose the first 4-5 inches then it would finally engage and only put pressue for about 2 inch's before the pedal ws at the floor... it should be engaging sooner... whats going on? any help? and is it expensive to fix and where should i go?
Old Apr 7, 2008 | 06:40 AM
mlc's Avatar
mlc
Have you ever bled the clutch? I would start there.
http://forums.s2kca.com/showthread.php?t=12154
You might also want to try this before you get into if the is a problem with the clutch it's self.
https://www.s2ki.com/forums/index.php?showtopic=370792
There are some adjustments you can do to the clutch pedel but I would do these things first and see if it helps the condition.
Let us know.
mlc
Old Apr 7, 2008 | 06:59 AM
Zeeb's Avatar
ok... i'll check that out, but its also something that just started this mornin.. never had a problem before
richardaguilar95
Sep 13, 2017 06:34 AM
Brndon
Mar 18, 2013 02:49 PM
caseh
Aug 19, 2012 12:31 AM
amartin
Feb 3, 2004 10:17 AM
