Possible Emergency Brake problem
Old Apr 19, 2015 | 07:16 AM
titus69's Avatar
Default Possible Emergency Brake problem
I have started getting a groan at first take off from the rear of the car after I replaced the right rear wheel bearing and hub. Only happens after it sits over night.Wheel bearing was pressed in correctly and I have rechecked tq on all nuts. It sounds like when the disk has rusted some and its eating that off but it has not rusted. I pulled the caliper on the right rear and it seems to work. Pins slide and the piston moves. The e brake pulls the springs but it did not move the piston while it was off but when I put it back together it seemed to operate as it should. The car holds on a hill with no issues. It seems to me the E brake is disengaging slow or not enough. Am I heading in the right way? Any help would be awesome. Thanks.
Old Apr 19, 2015 | 02:48 PM
Saki GT's Avatar
So, spend a night without using the e-brake and see if it still happens. Report back.
Old Apr 19, 2015 | 03:34 PM
windhund116's Avatar
Hand brakes are adjusted correctly?
Old Apr 19, 2015 | 04:22 PM
titus69's Avatar
That's what I'm going to do Saki GT. I went and got some wheel stops as I park on a hill sometimes.
Yes windhund116 I checked the amount of clicks by the book.
Thanks for the replies guys.
bgoetz
Jul 29, 2014 08:13 AM
VilleS2K
Nov 10, 2009 02:57 PM
jmlmr2
Jun 16, 2006 09:17 AM
MacGyver
Oct 14, 2005 06:25 AM
DaveB
Nov 3, 2004 01:16 PM
