Possible Solution: Reverse Engagement
Old Mar 1, 2012 | 08:40 PM
AZ-S2000's Avatar
Default Possible Solution: Reverse Engagement
So I noticed at sometimes its kind of hard to engage reverse, sometimes won't want to shift in reverse. So I shifted in 2nd and back into reverse and went perfectly smooth. So, try shifting in 2nd or 4th gear if reverse is hard to engage. Please let me know if that has any affect, worked for me
Old Mar 1, 2012 | 09:10 PM
afzan's Avatar
regrease your shifter, there's a DIY on the forums somewhere
Old Mar 1, 2012 | 09:41 PM
T-Smac's Avatar
Check clutch fluid level. There could also be air trapped in the clutch fluid.
Old Mar 1, 2012 | 11:14 PM
AZ-S2000's Avatar
Clutch fluid is changed. Much better pedal feel
Old Mar 1, 2012 | 11:23 PM
T-Smac's Avatar
Old Mar 1, 2012 | 11:29 PM
Tuan85's Avatar
i use the same method. I put it in 1st tho.
Old Mar 2, 2012 | 12:00 AM
S2k007's Avatar
Yeah I've been doing this for a while. I usually go into first. I need to regrease my shifter. DIY?
Old Mar 2, 2012 | 05:48 AM
beezlebubba's Avatar
agree about doing it for a while now and going into 1st
Old Mar 2, 2012 | 06:00 AM
ftpsk8's Avatar
As stated, regrease the shifter. Also put some fresh clutch fluid if your having this problem. Both of those should help drastically.
htown s2k
Feb 8, 2017 10:39 PM
rmk232
May 7, 2012 09:25 AM
Haulin' S
Jan 31, 2008 11:42 PM
JakLaw
Sep 20, 2006 08:46 PM
MattG
Sep 24, 2004 07:17 PM
