Post your Alignment
Old Jun 17, 2002 | 03:00 PM
  #61
dlq04's Avatar
[QUOTE]Originally posted by amtg4u
[B]Try going to this thread
https://www.s2ki.com/forums/showthre...?threadid=43091
It is the TSB for the revised alignment setting.
  #62
dlq04's Avatar
Old Jul 1, 2002 | 12:08 PM
  #63
JohnsS2K's Avatar
I just put a set of Buddy Club Racing Spec Coilovers on my S2000 and looking for some guidance on what my ALIGNMENT SPECS should be. I am also running 18" Volk LE37T's (Front 225/40, Rear 245/35 Toyo Proxes T1-S).
Thanks in advance for the advice.
Old Jul 3, 2002 | 03:13 PM
  #64
Schatten's Avatar
John, doesn't matter too much what you are running in shocks or wheels IMO, but I think a good setup would be one of those already suggested. What I typically recommend:
front camber -1.25 to -1.5 in the front
front caster +6 or as close to as possible
front toe - zero/0
rear camber -2.0 (or, because your car will probably be lower than a stock S, you should try to get as positive to that as possible)
rear toe 1/8" to 1/4" toe IN
Hope this helps.
btw, with new springs, let them settle for at least a week before getting them aligned.
Old Jul 3, 2002 | 08:07 PM
  #65
JohnsS2K's Avatar
Thanks!
Old Jul 4, 2002 | 01:13 PM
  #66
Incubus's Avatar
I know what camber and toe are,
But I don't know what caster is, a quick explanation would be cool.
Thanks.
Old Jul 4, 2002 | 02:43 PM
  #67
spider's Avatar
Simply put, if camber is the x axis, and toe is the y axis, then we can say caster is the z axis. For example, a motorcycle's front wheel has lots of positive caster.
Old Jul 5, 2002 | 07:59 AM
  #68
Incubus's Avatar
This makes nosense to me.
In this case couldn't you rotate the caster 180 degrees and still have nothing changed. It's a wheel, the Z axis would be rotating the wheel like it does when being rolled.
This is what I see.
Shine some light please.
Old Jul 5, 2002 | 09:50 AM
  #69
spider's Avatar
It's clearer with pics, I'm sure:
The above pic is from here:
http://206.117.169.65/alignment.htm
Old Jul 5, 2002 | 11:11 AM
  #70
Tedster's Avatar
When the steering angle is 0
