PASSENGER WINDOW INOP
Old Aug 26, 2008 | 11:09 AM
BrianTucson's Avatar
Default PASSENGER WINDOW INOP
Passenger power window quit working. Neither the driver's door nor passenger door switch will operate it, and cannot hear relays clicking when either switch is pressed. IT IS NOT THE ON OFF SWITCH ON THE DRIVER'S DOOR PANEL. Checked both fuses and they are also fine. Convertible top will not operate since either.
Any suggestions/ideas/ wiring diagrams?
Old Aug 26, 2008 | 01:52 PM
MikeyCB's Avatar
I know you checked em but it sure sounds like fuses to me...
I'd check all fuses under the dash and the hood to make sure there isn't some funny stuff going on.
Old Aug 26, 2008 | 04:35 PM
DFWs2k's Avatar
convertible top won't go down either? hmmm...I had my passenger window regulator go out, but I could still operate the top...
Old Aug 26, 2008 | 06:05 PM
negcamber's Avatar
Have you done any stereo work in the last couple months? New amp, speakers or head unit? Or have you taken the door panels off recently?
Old Aug 27, 2008 | 06:11 AM
Figured what it was. I was able to actually download a Service manual with the wiring diagram. After a couple of hours of pin checking, I found that the Convertible top module is bad. All input/switched voltage/ground into the module were fine, and good continuity from module to window driver motor, which works as well. Was gonna disassemble the module it and repair it, as it seems to be a relay feed voltage problem internally (the passenger window relays are inside this module, as it uses them to drive the windows down when the top is lowered.) Not sure what would even make it go bad in the first place.
I ended up trading the thing in on a Jeep anyways.
This particular S2000 has been a lemon since I bought it from a dealership (later found out it was in a wreck, as well as over-revved engine), and I have had so many bad experiences with dishonest Honda dealerships so far, that I doubt I will ever buy another Honda ever again, based on that fact alone.
Old Aug 27, 2008 | 07:36 AM
fltsfshr's Avatar
Intersting mine just did the same thing. I reviewed all the fuses. they were all ok.
Iwas going to start doing the helms continuity testing today. I'll start with the convert top module.
Thanks
fltsfshr
Old Aug 27, 2008 | 01:30 PM
fltsfshr's Avatar
thanks i have all the helms manuals, tested it today you were right.
appreciate it good luck with your new car
fltsfshr
Old Aug 27, 2008 | 03:12 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I remember when I got my car back from the body shop, the pass window didn't work (this was years ago when I first got the car) I pull the door panel, and start tracing wires. Get out the manual, and trace the no-power to "window switch" never do that again
connieholmes
Jun 22, 2013 12:53 PM
ghoward11
Jun 2, 2005 12:41 PM
dhayner
Jul 8, 2004 08:44 AM
ayelien
May 22, 2004 09:17 PM
maverick521
Apr 27, 2004 02:46 PM
