Price for replacing studs
Last night changing the setup of my coilovers, my brother broke one of the studs in the front left wheel. Do u guys know how much it will cost to replace it? Does honda cover it under warranty? Also, one of the nuts on the rear wheel kept on turning when locking the wheel and I'm afraid that lug is going to fall off too. Should I replace that one also?
Thanx
Thanx
Yes, you will have to replace both. It is most likely the stud stripping on the back one. The studs around only about $2-3 for each stud. You can replace them yourself. It is a pretty straight forward thing (not very difficult).
Bryan
Bryan
Bryan
Bryan
Originally posted by CoralDoc
Really? I thought it was a pretty involved process involving the removal of the hub. Please tell me I'm wrong and how to do the job easily.
If you can replace one without removing the hub why can't you rotate the hub and replace the next one and so on? Just curious. It doesn't make sense to me that you can replace one but if more than one needs replacing you need to take off the entire hub.
ryanswhites2k
21
Jan 22, 2014 04:26 PM
decker
Sep 2, 2005 05:11 AM
