Problem with convertible top
Old Feb 13, 2006 | 03:58 PM
S2KPUDDYDAD's Avatar
Default Problem with convertible top
I have a 2002 and lately the convertible top won't go all the way down. It just stops short of the fully down position.
I know this because I can not open the door between the seats with the wind deflector on it all the way now. The problem is interment but, more not working than working.
I was at the dealer today looking around and saw a 2005 S going out on a test drive and the sales person was having the same trouble I am having...top not going down all the way
Any help would be great the dealer wants $85.00 to look at it....
Old Feb 13, 2006 | 04:12 PM
milkbubble's Avatar
My top does that when its cold out.
Old Feb 13, 2006 | 07:01 PM
BigpoppaHurtm's Avatar
http://modifry.com/products/index.htm
This may be whats wrong. I believe Im having the same Problem on mine but Im too lazy to do anything about it. Good luck buddy.
BTW milkbubble's sig is very funny.
N ever
A gain
V olunteer
Y ourself
Old Feb 14, 2006 | 06:26 AM
Zeemz's Avatar
N ever
A gain
V olunteer
Y ourself
Thats probably the issue at hand.... My straps are not totally worn, but when its cold i see the problem happen more time then others. I usually keep one hand pushing back on the bar when i drop the top just to make sure.
Old Feb 14, 2006 | 10:20 AM
Spa_Ap1's Avatar
I do the same thing! I am just too lazy to fix it.
Old Feb 14, 2006 | 01:52 PM
N ever
A gain
V olunteer
Y ourself
Thank you $85.00 saved I will order this
Old Jul 5, 2006 | 12:40 PM
Stephenopoly's Avatar
S2KPUDDYDAD... any update on how the product worked? I just ordered it because i was experiencing the same problem with my 05 s2k.
-stephen
Old Jul 5, 2006 | 05:28 PM
sweetsleeper's Avatar
Don't worry, it will stop. That's what happened to me before. Just do it twice or three times each time until you get it all the way down. Watch the way it folds. Sometimes it doesn't do it right. You have to train it. Like having a permanent press. You have to manually fold it while it is going down. Luckily i don't have that same problem for about 3 years now.
Old Jul 5, 2006 | 05:31 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
All you need to do it keep light backward pressure on the moveable bar above your head when lowering the top.
It's a problem with all s2k's, and this will cure every single one for good.
I always do it with mine. If you don't, the tips of the levers will cut through the top.
Old Jul 5, 2006 | 10:06 PM
Much thanks for the tips guys, I'll give it a try. So its the First bar above my head that i need to watch out for?
-stephen
