Problem with motor
Old Feb 18, 2010 | 04:13 PM
2thousands2k's Avatar
Default Problem with motor
I have a 2000 S2k and when I accelerate sometimes at low rpms it has a sutter like its running out of fuel. I also have a problem when I accelerate hard to about 7rpms and it like hits it limit or something. I changed the spark plugs and the fuel injectors even still the fuel injectors are having low readings. Does anyone know what's going on? Did I blow my motor? Thanks
Old Feb 18, 2010 | 04:50 PM
XScarAudio's Avatar
what air filter are you running? maybe it's dirty?
I haven't done this on my s, but i had this issue on my old civic and it was the fuel filter....those are my first 2 guesses.
Old Feb 18, 2010 | 04:57 PM
datdude1119's Avatar
Maybe its the fuel filter?
Old Feb 18, 2010 | 05:24 PM
suzuka-blue-s2k's Avatar
If your getting low readings at the injectors (and have new ones) then its most likely a clogged fuel filter. Change it then see if it helps. That would be the first thing I would do.
Old Feb 18, 2010 | 10:16 PM
CapoArgentino's Avatar
Banned
Your not trying to hit VTEC while having less than 3 bars in the water temp gauge right? One bar and you will hit the invisible wall right before VTEC engages
The Raptor
Jul 15, 2013 08:00 PM
zeroptzero
Jan 14, 2010 03:40 AM
Black_SIIK
May 8, 2007 10:14 PM
s2000_19
Jun 9, 2005 09:44 AM
2000celicaspeed
May 14, 2004 02:59 AM
