Problem with the S
Old Jun 21, 2014 | 12:42 PM
Slowcrash_101's Avatar
Maybe you have a malfunctioning temperature sending unit.
Old Jun 21, 2014 | 02:09 PM
zeroptzero's Avatar
Originally Posted by Mpalm022
Thanks for the help guys. I went to Autozone and got the code reader, but it didn't pull any codes. I have 90 days with it,so i'm going to keep it in my car till the problem happens again. You think it's worth replacing the thermostat just to be safe?
I'd wait until the next time it spits out a CEL and if it is for low coolant temp then it likely is the thermostat, I wouldn't touch it right now as it is a bit of work swapping it out and you don't want to do it needlessly. You won't harm the engine.
Old Jun 21, 2014 | 04:16 PM
dwight's Avatar
So i brought my car to Honda to have this problem looked at, unfortunately being 22 years old they treated me very poorly..., any advice?
They treated you poorly because they're a dealership. That's what they do.
My advice is to never go back there.
But about the car, like JFUSION said, wait until you can pull a code.
Old Jun 21, 2014 | 06:03 PM
starchland's Avatar
Can you monitor coolant temp with the gauge?
Old Jun 29, 2015 | 05:51 AM
Mpalm022's Avatar
Please help!
Still cant figure out this problem. To Refresh, when the temperature outside is above about 70 degrees the car will not operate. A little after the car is all warmed up, the temp gauge drops back to one bar, and check engine light comes on, and it seems the car responds as if it were a cold start leaving it in a limp mode like state.
The worst part is that there are no codes that are saved on the computer. When the problem is happening the computer will also not give any information to the code reader.
I was told that the thermostat is opening and closing fine, and one shop thinks that the ECU might need a re-flash. I wanted to get your opinions on here before I start the guess and check game.
My next step is to give to the dealer and see what they say (that is if they will even work on it)
To add to this, when the outside temp is about 65 or below the car runs perfect.
HELP PLEASE I MISS MY S2K!!!
rjc1audel
Jul 29, 2016 01:08 PM
Mpalm022
Feb 22, 2016 01:24 PM
JoeyBalls
May 16, 2009 02:33 PM
Vortech'd
Oct 13, 2008 08:52 AM
ASMspec
Feb 25, 2004 11:13 PM
