problem-signals dont work
hello everyone,
2 weeks ago, my friend instal a radio, after a few hours, i was drive and the turn signal dont work, alarm signal works, the other lights from the left knob works,
but the signals, not. with the alarm signals i listen the relays work, and when i drive and press the knob to right for example , turn the steering wheel to the corner and back, the knob come back.
Someone knows what happens?
thanks.
thanks.
during the installation did they remove the center console ? , if so they may have left the connector for the hazard switch disconnected. If you forget to connect the hazard switch you won't have any turn signals. While you are in there you might as well check the roof switch to , if one was not connected then both may have been left disconnected.
bjeong1381
20
Nov 1, 2006 10:20 PM
