problem solved
Old Feb 2, 2013 | 08:25 PM
i_luv_s2k's Avatar
Default problem solved
sup s2ki fam,
Finally replaced my wheel studs + bearing! Upon removal of the rear ball joints, the boots seem to have squished out some grease. Upon reinstallation, there is a slight, but noticeable gap between boot and joint (yes, the joints are correctly installed, and the nuts are tight). It's as if the KD tools ball joint separator I used (yes, I went under the boots) compressed the boots and they stayed that way.
Is this normal? The boots are still in good condition (no rips). I know it's a sealed chassis, but is there a way to "inject" grease inside the joint? Maybe with a "flavor injector"? lol
thanks in advance!
peace
StellarS2k
Nov 18, 2013 12:07 PM
cdelena
Sep 20, 2013 05:42 PM
i_luv_s2k
Feb 3, 2013 12:07 PM
Breaking Point
May 4, 2012 03:25 AM
badboy00z
Oct 20, 2010 04:18 PM
