problem starting car
Originally Posted by SimbaDogg,Feb 7 2009, 02:06 PM
yeah, i've already started looking around for shops to do work...
Originally Posted by negcamber,Feb 7 2009, 08:40 PM
Post up in your local s2ki forum and ask for a shop recommendation. As long as the head has to come off you might as well have it rebuilt. And it should go to a machine shop anyway to make sure it isn't warped.
Originally Posted by ikeyballz,Feb 8 2009, 04:02 AM
By the way, since everything is going to be off...find out what cuased it to overheat in the first place. Or everything is gonna be screwed up after its fixed.
Just remember that there are limits to how much you can mill off the head surface. The manual lists service limits for flatness and how much can be machined off. Yours sounds like it might be really trashed. If it's too warped, you are probably better off getting a new head. You should be able to get a bare head for a couple hundred bucks, then move all the cams, springs, etc. over to it.
[EDIT] And for God's sake, fix the cooling system leak while you are at it.
riceball777
Oct 26, 2011 11:53 AM
