Problem with water in tail light
Old May 28, 2009 | 04:28 AM
bj84's Avatar
Default Problem with water in tail light
Hi
I've a litle problem with water in tail light inside the car. Water is allways after very very pour rain and I can see them when I twist soundly left or right side during the drive. (Beads from the light). My soft top is in perfect condition , no of hole rubbing etc
Any ideas??
Thanks for help
Old May 28, 2009 | 08:15 AM
tronvex's Avatar
Maybe try removing the bulbs and put a hair blow dryer at it. That might warm up the water molecule and cause it to evaporate. I don't know how a spider work its way into my passenger side tail light, but now it dead
Old May 28, 2009 | 10:57 AM
Jwslick's Avatar
yea I have had problems with condensation in my tail light.Take it to the dealer.I should be covered under warranty
Old May 28, 2009 | 12:04 PM
JayJones's Avatar
Mine was doing the same thing, i took the tail light off, put it back on, made sure all the bolts were tight and it was seated properly, and it hasnt let water in since.
Old May 29, 2009 | 06:18 AM
bj84's Avatar
...new thing. I discoverd that the beads from the light are only when I'm twisting only in right side...
Old May 29, 2009 | 09:08 PM
Homer Simpson's Avatar
hmm...
I don't know how to help you but atleast you don't have a spider web inside your tail light with a dead spider in it...
Old May 29, 2009 | 11:42 PM
tronvex's Avatar
Yeah that true, I'm glad that it just die and didn't build a home in there
Old May 30, 2009 | 02:13 PM
damuho's Avatar
I had the same problem with my passenger side taillight. I found that water creeps from under the taillight even from soapy/bubbly water when gentle washing (no direct spraying). No more problem after I put silicone sealant all around.
I drilled a hole from the top to clean the dried water at the bottom (with a wire hanger and pieces of cloth at the end) then sealed the hole when I was done.
dustin02rsx
Nov 24, 2014 11:23 AM
tolin1124
Jun 18, 2008 06:12 AM
andrewboro
Mar 8, 2006 03:35 PM
s_tu_k
Jun 9, 2005 03:55 AM
WhiteS2k
Jan 14, 2002 11:11 AM
