PRODRIVE WITH SPLUSH HUB. upgrade
https://www.s2ki.com/forums/index.php?showtopic=264411
ok i follow every single instruction and my srs still on
anybody have clear pictures...... i know its clear but my splash hub came with all 3 wires and it suppose to disable srs light but at this moment its not working.....
HELP.......
HELP.......
do you guys think i blew a fuse?
i also have a question about what wires suppose to go on what wire...
for example the srs yellow prong shown bottom pics... my question is what wires should go on this..
now i have a question do i have to put a wire on the gray plug... shown below...
now for final picture see the plastic piece they are 3 wires that suppose to disable the srs now can someone chime me in on this .... which wire is which
thanks in advance
sean
im a little confuse now since i follow every single step on this set up...
thanks in advance
sean
ok more problem now
i put back my steering wheel and my srs is light is still on
1. i check the fuse and its not burned
2. i double check every connectors..... everything is plug..
3. can anyone help is there another fuse that i should look for....
Just my 2 cents
Remember that the SRS system will detect the lack of an airbag if you placed the key in the ingition during the install, I believe that this might result in the SRS light being permenantly illuminated until the fault is cleared from the SRS system via a MES connector. Even if you reinstall everything back to normal the fault is still logged in the SRS system. I could be wrong on part or all of this, but well its some food for thought for ya.
I have this mod.........don't have this problem.
