Prop Shaft play
Old May 5, 2006 | 10:36 AM
gfacter's Avatar
Default Prop Shaft play
Lately I have noticed a slight rattle noise at low speeds coming from the rear of the car. I recently put in a 4:57 dif (February)
I have adjustable metal sway bar mounts (had for 2 years) and they make a little noise when cold, but quiet up after a few miles.
Today I got under the car to double check all the diff mounting bolts (all were torqued to spec) just to make sure nothing loosened up.
I did however notice a good amount of play in the Prop shaft, maybe a 1/4 inch and it makes a little noise when I rotated the tires.
I know there are the CV joints and u-joints in the axle and the diff all need some play. Is this much normal?
Suggestions?
Old May 5, 2006 | 11:19 AM
oakfloor's Avatar
Suggestions?
do you hear a gear whine? may be the transmission tailshaft bearing wornout?
Old May 5, 2006 | 11:22 AM
gfacter's Avatar
A little whine at cetrain RPM, but I thought that was normal for the Gear sets.
Old May 5, 2006 | 11:44 AM
oakfloor's Avatar
You might have someone check it out if it starts getting louder. Also take a sample of the diff, and tranny oil and send it to blackstone labs. and it will tell you if it gears or bearing ware.
Ek_Jak
Aug 26, 2009 01:25 AM
RangOs2000
Aug 15, 2009 05:12 AM
pli
Jun 14, 2008 02:59 AM
BlueS2000Boy
Oct 10, 2003 08:01 AM
