Pss9 help
Old Jan 8, 2008 | 02:13 PM
DC2AP1's Avatar
Default Pss9 help
I just install my Pss9...and I have 2 problems..First..my "helper spring" "small one" in the back is completly compress , is that normal ? with a inch drop
second..i can't get a nice drop ? unless I drop the suspension completly
thx
edited
Old Jan 8, 2008 | 02:28 PM
iDomN8U's Avatar
There is a recommended amount, there coilovers aren't meant for slammage.
I believe it's recommended spot is around 1.5", but that should be included with the instructions along with a guide
Old Jan 8, 2008 | 04:00 PM
Stratocaster's Avatar
The small helper spring are only there to keep the main spring seated when the suspension is completely extended. Nothing more. So yes, that is normal.
This makes not sense at all.
"second..i can't get a nice drop ? unless I drop the suspension completly"
The body of the shock is threaded, you can adjust it from a full, drag on the ground drop (been there, done that) to stock height and everywhere in between.
Old Jan 8, 2008 | 04:43 PM
DC2AP1's Avatar
no thats the problem..i have 1/4 inch threads left and a fat finger gap still
but like idomN8U said.maybe those Pss aren't meant for slammage ...!
Old Jan 8, 2008 | 04:55 PM
You are looking at the car without any weight in it and with springs that have not settled.
But if yours are that differant from mine I would be suprised. Mine will drop the car too low to even drive.
Old Jan 8, 2008 | 05:28 PM
DC2AP1's Avatar
well...let's after they settle themself..hopefully my problem will be gone
Can you give the measurement you have ..front and rear
thx
ipopvtec
Mar 29, 2012 06:46 PM
1wides2k
Oct 2, 2011 10:13 AM
acelaluces
Mar 23, 2011 06:51 AM
bkowa092
Mar 16, 2011 09:44 PM
elude
Sep 4, 2008 09:38 AM
