Ptuning (Manassas, VA) Clutch Install Question
Question for you guys.
On December 6, 2012, I had Ptuning replace the pressure plate, friction disk, and flywheel on my 2000 S2k. Everything turned out great BUT fast forward to this past Sunday. While I was installing spring/shocks and exhaust, I found this:
It’s a picture of the propeller shaft and if you look closely, next to the allen bolt is a hole. I don’t know how it was punctured by I suspect that Ptuning punctured the propeller shaft during the clutch install.
Here's a picture of grease flung from the propeller shaft on the undercarriage:
I called Ptuning and they want to take a look at it. I have an appointment for the tech to look at it tomorrow (3/28). They told me that consider that it’s a 13 year old car and it could be seals going bad but I told them if they look closer, you can see that the metal was punctured. They say they’ll need to look at it.
Do you think they’ll own up to their mistake?
I don’t know how else to explain the hole in the propeller shaft.
Any ideas? ...thanks in advance.
Yea I know... but I don't know how else to explain the damage to the propeller shaft. Thanks though.
Originally Posted by Slows2k' timestamp='1364430449' post='22433382
That hole was made by a cutoff wheel or chisel.
