Pulling to the right under braking
I've seen this problem before on a different car. It turned out that one of the brake hoses going to one of the calipers was damaged internally. There was a small cut inside the hose that allowed the brake fluid to branch to a different part of the hose, but the hose looked fine externally. When the pedal was pushed, the brake fluid in the line would go the wrong route and effectively pinch off the line so that no more pressure would reach the caliper. Therefore, the opposite side of the car would be braking harder. This only happened when the brake pedal was applied at a medium to hard level.
Also, like vapor says, the car may track straight, but your alignment can be way off. If for example your right camber is 2
AndyThomason
Jul 31, 2006 04:07 PM
