Question
Old Sep 6, 2005 | 11:16 AM
00s2k9k's Avatar
Default Question
im swaping a jdm motor into my s2k and i was wonder if the chip in the key will effects it from not starting cuz it might not read the jdm ecu...jus wondering if neone had any ideas of what i can do
Old Sep 6, 2005 | 11:30 AM
CIVICTOS2000's Avatar
whats the difference between the JDM motor and the USM motor? Sorry I did know about this!
Old Sep 6, 2005 | 11:44 AM
Asura's Avatar
Use your original ECU.
Old Sep 6, 2005 | 12:07 PM
mbilderback's Avatar
JDM compression is 11.7:1, USDM is 11.0:1.
I would also say you should try and use the USDM ECU if you can. JDM ECU has a rev limiter at 180km/h I believe as well as serious reprogramming issues for the key. If you do decide to use a different ECU, you will have to go to Honda and have them program the ECU to accept the key.
Old Sep 6, 2005 | 12:14 PM
Wisconsin S2k's Avatar
the JDM ECU won't start with your current key. it'd have to be reprogrammed and i dont know if anyone in the US can do it?
Old Sep 6, 2005 | 12:16 PM
00s2k9k's Avatar
yea i donno....wouldnt that effect hp..i no that it has 10hp then the usdm...but if it dont work then im force to use the usdm...lets see what other people say....
Old Sep 6, 2005 | 12:17 PM
CrazyPhuD's Avatar
Ummm....actually the JDM ECU shouldn't be a problem...provided it IS actually a JDM engine ECU. I'd be willing to say that 99.99999999% of 'JDM engines' on places like ebay are actually USDM.
Remember the JDM s2k doesn't have the imoblizer...no imobilzer no issues with the key.
Old Sep 6, 2005 | 04:21 PM
white_S2000@16's Avatar
if you really have a jdm s2k with 11.7:1 cr youll have issues with using 93 oct and the USDM ecu or if you use the jdm ECU and have the 11.7:1 motor youll have issues with 93 octane, just a thought but then agian who siad you were using 93 octane???
Old Sep 6, 2005 | 06:54 PM
00s2k9k's Avatar
i do run 93 octane...i got the motor from jspecautosports.com....so it wont be an issue if i use the jdm ecu right...
petros ae86
Κινητήρας - Μετάδοση - Περιφερειακά
Mar 22, 2013 05:06 AM
darkknight
May 19, 2011 12:30 PM
socals
Mar 24, 2008 12:43 PM
ocd_2k3
Oct 23, 2007 12:10 PM
