Question about airbag system
Old May 2, 2006 | 05:59 PM
Hammerhead's Avatar
Default Question about airbag system
I have a question about the SRS Airbag System. If the car was hit in such a way as to activate the switch (but not tear the crap out of the car) and you got in and turned the key. Would the Airbag deploy or would it happen at the time the car was hit?
Old May 2, 2006 | 06:10 PM
mad-dog-one's Avatar
Good question. That would teach you to never want to push a red button again. I'll be watching for a reply from someone who knows.
Old May 2, 2006 | 06:50 PM
Spoonie's Avatar
As soon as the SRS is activated it will set off the airbag that it was sent to. Even if there is no extreme damage.
Old May 2, 2006 | 06:56 PM
Elistan's Avatar
Even if the car is turned off at the time?
Old May 2, 2006 | 07:01 PM
Spoonie's Avatar
I had no idea about that one so I called my local tech guy and he said it would not go off because the sensor would not be activated.
Old May 2, 2006 | 07:24 PM
Slows2k's Avatar
If the ignition switch was off and the vehicle not moving the bags will not deploy. The bags will not deploy when you turn the switch on after the car was hit.
The key must be on, the car must be moving and the sensors inside the SRS controller must be decelerated or accelerlated fast enough that the controller deems deployment is needed.
Old May 3, 2006 | 06:48 AM
Wisconsin S2k's Avatar
Old May 3, 2006 | 12:54 PM
madcowdk's Avatar
Don't the sensors need to be replaced after that, though??
Old May 3, 2006 | 01:06 PM
S2nOC's Avatar
what if youre jus sitting in the car parked on the side of the road key out of ignition, and BAM , someone comes and rear ends you. It wont deploy?
Old May 3, 2006 | 01:25 PM
tbaker's Avatar
[QUOTE]S2nOC Posted on May 3 2006, 05:06 PM
