Question about Steering EPS Reset
I had honda do some work (SB 00-154) When I got the car back I noticed that the steering wheel was off center. I have concluded that they failed to set the torque sensor neutral position. My question is, will this harm the car in any way. I have been driving alot and I hope I'm not hurting my baby!!!
Would it be possible to reduce the amount of assist? I feel that the reson the steering feels "dead" is that there is too much assist... though I'm not sure how much it's applying at speed- it may be that the car is just that light.
This is from the FAQ:
"The EPS control unit stores the memory of torque sensor neutral position in the EEPROM. Perform memorizing the torque sensor neutral position whenever the gearbox is removed/installed and the torque sensor or EPS control unit is replaced."
If this wasn't done it would not have any affect on the position of my steering wheel when the wheels are straight? I'm asking cuz I really don't know. The steering was not off before I dropped the car off at Honda. Hmmmm...
Several of us have had the same problem with the wheel being off center after the clutch tsb. I had them re-align the car and center the wheel 4 times and it still isn't perfect. A couple of other guys said the front subframe has to be loosened and it is probably causing the wheel to be off center if it didn't get aligned correctly when it was retightened.
AZS2KDancer
Feb 18, 2017 10:54 PM
