Question about Steering EPS Reset
Old Oct 10, 2001 | 08:36 PM
s2kbug's Avatar
Default Question about Steering EPS Reset
I had honda do some work (SB 00-154) When I got the car back I noticed that the steering wheel was off center. I have concluded that they failed to set the torque sensor neutral position. My question is, will this harm the car in any way. I have been driving alot and I hope I'm not hurting my baby!!!
Old Oct 10, 2001 | 10:03 PM
krazik's Avatar
Administrator
If your steering wheel isn't straight you need an alignment.
The EPS reset is to change the amount of torque the powersteering puts out to move the wheels.
Old Oct 11, 2001 | 04:58 AM
marcucci's Avatar
Would it be possible to reduce the amount of assist? I feel that the reson the steering feels "dead" is that there is too much assist... though I'm not sure how much it's applying at speed- it may be that the car is just that light.
Old Oct 11, 2001 | 08:47 AM
s2kbug's Avatar
This is from the FAQ:
"The EPS control unit stores the memory of torque sensor neutral position in the EEPROM. Perform memorizing the torque sensor neutral position whenever the gearbox is removed/installed and the torque sensor or EPS control unit is replaced."
If this wasn't done it would not have any affect on the position of my steering wheel when the wheels are straight? I'm asking cuz I really don't know. The steering was not off before I dropped the car off at Honda. Hmmmm...
Old Oct 11, 2001 | 02:05 PM
RicePimp's Avatar
Good question. I've wondered about this before. Would turning the wheel more than 45 degrees during the EPS reset do this? How does it feel if you completely disable the EPS? I'm guessing that the effort would probably be unreasonably high with the quick ratio steering. The lack of feel seems to me the biggest fault with the s2000. I think a little less assist in exchange for better feel would be welcome by some owners. Anyone have any experience with this?
Old Oct 12, 2001 | 02:43 AM
walter_s's Avatar
This is exactly what i think about the power steering of S2K.
If anyone knows how to get less power assistance, please post it.
For me it's the only thing I don't like in driving the S2K.
Old Oct 12, 2001 | 05:31 AM
stocks2k's Avatar
Several of us have had the same problem with the wheel being off center after the clutch tsb. I had them re-align the car and center the wheel 4 times and it still isn't perfect. A couple of other guys said the front subframe has to be loosened and it is probably causing the wheel to be off center if it didn't get aligned correctly when it was retightened.
Old Oct 12, 2001 | 10:06 PM
s2kbug's Avatar
I got the car back from Honda today and now it is crooked in the other direction
Viggen
Nov 11, 2019 01:41 PM
magician
Jun 22, 2019 06:30 AM
AZS2KDancer
Feb 18, 2017 10:54 PM
Monacos2k
Apr 5, 2014 11:20 AM
PZ
Mar 18, 2001 06:24 PM
