question concerning TSB's
Old Feb 28, 2003 | 11:38 AM
dctrpark's Avatar
Default question concerning TSB's
i am about to purchase a used my00, and i wanted to ask if there is a maximum number of miles you can have to have the tsb's done. i've talked with the owner and none of the tsb='s were performed but then again when i drove the car, none of the tsb symptoms were noticeable. Should i take the car in anyway and have honda perform all of the tsbs?(or at least the important ones?)
what do you guys think?
thansk
Old Feb 28, 2003 | 11:49 AM
Gernby's Avatar
Former Sponsor
TSBs are not the same as recalls. You can't expect a dealer to perform TSB work without symptoms. Some dealers may be willing to do it, but you can't demand it.
Old Feb 28, 2003 | 11:53 AM
dctrpark's Avatar
if thereare symptoms and you are outside of the warranty period, will the dealer still perfomr the tsbs?
thanks
Old Feb 28, 2003 | 12:01 PM
Gernby's Avatar
Former Sponsor
thanks
Nope. That is another difference between TSBs and recalls. A TSB is just a bulliten to dealers about relatively common problems. If the car is under warranty, they don't charge for the repair.
EDIT: The dealer will sometimes do a repair after the warranty period for "good faith". The existance of a TSB for a particular problem may increase your chances of a good faith repair.
payyourtoll
Jan 28, 2006 08:05 PM
vader1
May 25, 2004 07:18 AM
REDS2KCA
Dec 5, 2003 08:39 AM
S2K_LA
Mar 6, 2002 10:21 AM
