Question On How To Install The Diffuser
Old Jul 13, 2004 | 09:01 PM
chobits's Avatar
Default Question On How To Install The Diffuser
I'm really sorry to ask about this thing again.
I bet it's been posted hundred times already, but I just couldn't find it.
If you can give me the link with pictures?
thanks a lot
Old Jul 13, 2004 | 09:09 PM
yummyph0916's Avatar
go to ricks2k.com and there is a diffuser installation link
Old Jul 13, 2004 | 11:07 PM
chobits's Avatar
the only thing that I can find is how to clear the diffuser by cooking the headlights and how to install the sidemarker.
I can't find the one for installing the clear diffuser w/ pics
Old Jul 14, 2004 | 03:38 PM
chobits's Avatar
no one wanna help?
Old Jul 14, 2004 | 04:11 PM
wortham's Avatar
you already found it, bro. cooking the headlights is part of the install for the diffusers. it's that set of instructions along with its pics that you'll need.
Old Jul 14, 2004 | 04:59 PM
RotoRooter's Avatar
or take off your headlights and send them to Ricks for a replacement with clear diffusers
Old Jul 14, 2004 | 05:05 PM
w1ngman's Avatar
What others have indicated here is accurate. Just read Rick's instructions. Once you've baked the headlamps and split open the halves of the headlamp assembly, you'll gain access to the amber OEM diffuser. Lay the clear front half of the headlamp assembly face down on a towel (something soft & scratch free). A phillips screw driver will be needed to remove 3 screws that hold the diffuser [and its chrome reflective dish] into the headlamp housing. After removing the screws, gently pry back two retaining clips. Then the diffuser & its chrome reflective dish come out together. The amber OEM diffuser can be removed from the chrome reflective dish by gently prying back on two retaining clips molded into the OEM diffuser. Bingo-bango...you've removed the diffuser...
Old Jul 15, 2004 | 06:34 AM
StknCaS2k's Avatar
To install the side marker, grasp the side marker and pull it towrds the rear of the car, and it will pop right out. Unplug it, and reverse procedure to install the new clear side marker.
Old Jul 15, 2004 | 08:00 AM
w1ngman's Avatar
... And remember you nearly need three hands though to do this simple mod. Because if you don't hold onto that "unplugged" wire harness......it likes to fall down behind the fenderwell . One easy remedy is to have some lite-stick masking tape handy and just tape the harness/wire aside while you swap the side markers & bulbs out.
Old Jul 15, 2004 | 04:58 PM
SilverKnight's Avatar
I was taking my side markers out for practice when my clears come in and but I pressed it to the front of the car and man it did pop out but it took awhile......Didn't know you had to do it in reverse!!
GPWVANCITY
Apr 3, 2007 12:02 PM
fobMD
Feb 28, 2006 11:23 AM
Hamiy
Jul 1, 2005 07:09 PM
Hamiy
Jun 8, 2005 10:01 PM
Globetro
Dec 9, 2002 04:08 PM
