Question on installing X brace.
Old Aug 23, 2003 | 05:52 PM
1FastS2k's Avatar
Default Question on installing X brace.
I haven't done it yet and don't want to run into problems. Is it better to have the front wheels supported on ramps, or just use jack stands at the proper locations with wheels hanging?
Old Aug 23, 2003 | 07:04 PM
Stratocaster's Avatar
Either way should be fine.
Old Aug 23, 2003 | 07:27 PM
honda9krpm's Avatar
If you find it difficult to line up the brace, as I and a number of members have found out, you can loosen those bracket where the brace meant to go on. You will know which one when you are underneath the car. It will make things easier
Old Aug 25, 2003 | 02:54 PM
Uncle Fester's Avatar
[QUOTE]Originally posted by honda9krpm
[B]If you find it difficult to line up the brace, as I and a number of members have found out, you can loosen those bracket where the brace meant to go on.
Old Aug 25, 2003 | 03:01 PM
matrix's Avatar
Also make sure your car is as level as possible so that the xbrace is not stressed while putting it on...thanks to Xviper for that tip ....
Old Aug 25, 2003 | 03:44 PM
seminole2001's Avatar
Anyone know what the bolts are supposed to be torqued to?
Old Aug 25, 2003 | 04:29 PM
matrix's Avatar
28 or 29 ft #s.
Old Aug 25, 2003 | 04:58 PM
1FastS2k's Avatar
Thanks for the advice, I'm going to do it tonight.
Old Aug 25, 2003 | 06:22 PM
Money2536's Avatar
It took me ten times longer to jack the car up and put it on stands than it did to put the brace on. I'm not extremely mechanically inclined, and it took me a total of about 20min to jack-up and install. Took stock bolts off and put new one in.
Matt
Old Aug 25, 2003 | 08:45 PM
Incubus's Avatar
It took me forever. I stripped the thread in the sub-frame or whatever that piece is you mount the brace to. Turns out it was a nut welded to the car. Had to tap a new thread in the nut and run a new bolt in there. Big trouble, but the results are definitely noticeable.
