Question on startup
Old Nov 2, 2025 | 01:37 AM
donconde3's Avatar
Default Question on startup
The last handful of times I’ve started my AP1 (00) it has stumbled and then recovered. Drives normal, this only happens on start up. What do you think? Plugs? Wires? Let me know…
Old Nov 2, 2025 | 01:43 AM
donconde3's Avatar
My video won’t upload, working on getting It up so you can see and hear it.
Old Nov 2, 2025 | 01:49 AM
donconde3's Avatar
Hope this works
File Type: mov
Old Nov 2, 2025 | 04:28 AM
Slowcrash_101's Avatar
Is your car still on the original fuel pump relay? I wonder, mine looked like crap after 23 years, and the car worked fine until like 3 months ago. You could have a failing connection on your fuel pump relay and never even realize it until the car starts shutting off on you and starts idling and driving funny.
Old Nov 2, 2025 | 04:30 AM
This is what the contact looked like on my fuel pump relay, and it was making my car shut off. It was the original one, it was probably this bad for a while, but it only started giving me issues now. Maybe you should check yours and resolder any bad connections. I honestly wonder how many issues on people's cars this could fix.
Old Nov 2, 2025 | 08:16 AM
Things affected by the fuel pump relay
Water temp sensor
Intake air temp sensor
Idle air control valve
fuel pressure
knock sensor
All of those things affect engine performance, whether idling or gunning it.
Old Nov 2, 2025 | 02:58 PM
cosmomiller's Avatar
Top Answer: 1
I wonder what Billman has seen over the years.
Old Nov 3, 2025 | 06:15 AM
jnewtons2k's Avatar
Has there been a significant drop in temps in your area?
I've noticed on my S that when the temps drop, the start up will be a little rough, but after a few seconds it perks up and runs normally.
Old Nov 3, 2025 | 07:08 AM
windhund116's Avatar
Especially if the battery is borderline old.
StankyS2k
Mar 15, 2022 03:43 PM
RayRay313
Apr 24, 2014 12:06 PM
Diz
Jan 3, 2008 03:55 PM
