Quick question about valve adjustments
Old Jun 30, 2012 | 02:17 PM
dbchang's Avatar
Default Quick question about valve adjustments
i recently did a valve adjustment on my 01 ap1 and my check engine light came on, i scanned for the code and got p0411. i double checked all the lines and everything seems to be intact, i reset the ecu and the code popped up again.
i unplugged everything and replugged it back in and the code popped up again
when i did my valve adjustment i did the go, no go method.
my question is, could it be possible that when i did the valve adjustment, the gap on the intake side is too small, and that is causing the check engine light to come on? or should i be checking somewhere else?
Old Jul 1, 2012 | 08:48 AM
dbchang's Avatar
anyone?
Old Jul 2, 2012 | 04:24 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
P0411 has nothing to do with the VA.
check the routing of the vac lines.
Old Jul 2, 2012 | 11:21 AM
dbchang's Avatar
Thanks! Yesterday i was inspecting all the plugs and i noticed the pcv valve wasnt rattling when i was shaking it. Its pretty old so ill replace that first and go from there
Phantom327
Apr 13, 2017 11:11 AM
codyh
Jul 23, 2012 03:41 AM
ragamuffin
Jul 20, 2008 03:43 AM
JimmyB
May 3, 2005 10:32 AM
