Random Electrical Issue Causing Engine To Stall
Old Jul 14, 2016 | 09:47 AM
s2000Junky's Avatar
Old Aug 1, 2016 | 03:07 PM
caurilio's Avatar
Just as a follow up, I have put just shy of 400 miles on the car since I discovered the spot on the wiring harness and have had no further issues. Probably one in a million chance of this happening to someone else, but if you ever drop the engine with the harness still connected, double check that the harness is properly secured out of the way of the clutch pedal
Old Aug 1, 2016 | 03:25 PM
Car Analogy's Avatar
Excellent work! If nothing else, hopefully you've inspired others that when they have a perplexing issue, stop, think, look. Think some more. Try random seemingly unrelated things. Look some more.
For something like this, being an S2K expert might not have mattered. Being observant, inquisitive, experimental, thoughtful, these were the critical qualities. Such may be the case for someone elses issue.
If you have a weird issue, dont give up. Think outside the box. You can do it!
Sent from my SM-G920P using IB AutoGroup
evanf
Apr 4, 2016 10:43 AM
Cudder
Jul 24, 2011 09:45 AM
Bionic Man
Apr 8, 2007 10:03 AM
rlaifatt
Nov 24, 2004 09:15 AM
Joe in STL
Sep 27, 2004 06:40 AM
