Shifter vibration and noise
Old Jul 31, 2016 | 02:11 PM
mrjoey350's Avatar
Default Shifter vibration and noise
Have a 2001 with 106K on it. The car has a lot of vibration and noise that can be felt and seen in the shifter. It goes through the gears well with no grinding or jumping out of gear. New Honda clutch installed with 3 new bearing in trans and oil in trans also changed...genuine Honda. Drivers and shifts better with new clutch, BUT not as good as it should be. Any suggestions would be appreciated.
Old Jul 31, 2016 | 02:42 PM
Slowcrash_101's Avatar
So the shifter shakes or the whole car?
Old Aug 1, 2016 | 03:19 PM
Z32MadMan's Avatar
Your motor mounts and/or trans mounts are trashed.
Old Aug 1, 2016 | 03:36 PM
Car Analogy's Avatar
Which, depending how tgey changed your clutch, could have been caused when the work was done. Too much strain on mounts trying to tilt motor.
Sent from my SM-G920P using IB AutoGroup
Old Aug 1, 2016 | 03:48 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
OEM shifter,or short shifter???
S2cav38
Jun 27, 2014 09:30 AM
Mastayado55
Jul 5, 2013 02:40 PM
JAPCAB
Sep 14, 2007 02:27 AM
s2k rookie
Apr 6, 2007 08:19 AM
c2d2
Nov 17, 2005 05:45 AM
