Random tech high flow cat..
Old Jan 4, 2002 | 10:28 AM
DouglaS2000's Avatar
Default Random tech high flow cat..
Does anyone know what the gains are on this higher flowing catalytic converter? There's a groupbuy for it but I'm not sure if it's worth installing on my car..
Old Jan 4, 2002 | 12:40 PM
SilverSurfer's Avatar
I have a high flow cat but not sure what gains are if any. I went with a high flow cat because of the SC.
Old Jan 4, 2002 | 12:46 PM
Takashi KazuMori's Avatar
Basically, all high-flow cats are the same ... Doesn't matter what brand, make or country of origin. You get about 5ps or somewhere around that, power that you cannot feel and for that matter ... I wouldn't even think about buying one, the OEM cat is made up of better quality nevertheless. Changing a high-flow cat on a stock exhaust system is useless, simply because your restrictive muffler is still in place. If you have like an N1 exhaust system, it might be good but once again you cannot feel the difference if you already have this exhaust system installed prior to the cat.
Old Jan 4, 2002 | 12:55 PM
That's what I figured... thanks all..
Old Jan 4, 2002 | 01:49 PM
bayarea408's Avatar
i dont think getting a new CAT or even taking it off will gain significant increase in HP.
only makes your car smell like crap.
Old Jan 4, 2002 | 01:56 PM
I just asked because replacing the cat with a higher flowing one does free up significant amounts of hp on larger displacement motors as a couple friends have replaced theirs and gotten 10-12hp from it.
Old Jan 5, 2002 | 02:53 PM
shaner's Avatar
In the spring I am going to dyno with and without the cat (I have a BYS straight pipe) and then with the Mugen ECU and then stock ECU... I will post comparison dynos on the board. I bet the cat makes no difference at all...
d21x
Dec 24, 2014 10:01 PM
MUAY_THAIerd
Feb 18, 2008 04:17 PM
S2K TX
Apr 24, 2004 02:51 PM
mikecl713
Sep 20, 2003 08:31 AM
Jeff
Jul 18, 2001 01:17 PM
