? re maitenance light
Old Dec 16, 2002 | 07:10 AM
brotherlouie's Avatar
Default ? re maitenance light
Hello Everyone,
I was driving home last night on the freeway. Goin' about 70mph in 6th gear, suddenly i felt like the engine was loosing power and i notice the maintenace light flasing for about 20 sec. then everything went back to normal. And now when I start the car I see the light flashing. My question is that does the light always flash when starting the car and how many times is it suppose to flash?
Thanks in Advance......
Old Dec 16, 2002 | 07:43 AM
ricklobo's Avatar
and the first question back usually is...
"What mods are done to the car ? "
This helps qualify your dilemna...
(but the short answer is that light is a dummy light rigged to go on every 7500 miles... and it flashes a few times upon start-up, but will flash more the closer you get to that next 7500 interval period, and then the light just stays until until it is reset...)
Old Dec 16, 2002 | 05:58 PM
CoralDoc's Avatar
Are you confusing the maintenance light with the check engine light? The maintenance light only serves as a reminder to have service performed. As ricklobo stated, it starts flashing for several seconds after the ignition is turned on about 6k miles after being reset, and comes on solid about 7.5k miles after being reset. It does not indicate any abnormal engine operation, but is simply a reminder that comes on at specific mileage intervals.
The check engine light indicates that the ECU has detected an engine operation fault. The codes can be downloaded with a scan tool.
Old Dec 17, 2002 | 01:43 PM
Gernby's Avatar
Former Sponsor
Are you sure it comes on at 7500 miles? I think mine came on at close to 6K, 12K, etc.
Old Dec 17, 2002 | 04:33 PM
Busch's Avatar
it starts to flash at 6k, and continues to flash until 7500, where it just stays on....bugged me too, until i read the manual (it also tells you how to reset it if you wish)
Old Dec 17, 2002 | 04:40 PM
xviper's Avatar
If you felt the engine lose power, this would not be associated with the "maintenance required" light. Are you sure it wasn't the "Check Engine Light"?
Old Dec 19, 2002 | 09:44 PM
Utah S2K's Avatar
Was it the pictureorf the oil can or the engine that was blinking.....to put it in laymans terms.......
Utah
SDS2K@9K
Jun 14, 2007 11:23 AM
03 S II K
Jan 13, 2004 11:00 PM
Zach H
Nov 16, 2003 10:05 PM
