Really Bad Leakdown Test
Old Dec 16, 2014 | 08:23 PM
TacomaDude's Avatar
Default Really Bad Leakdown Test
So, My 2007 with 108,000 miles has recently become somewhat more difficult to start in cold weather and runs a little rough until it warms up.
I took it to a local dealership, who couldn't find anything wrong but decided to adjust the valves and do a leakdown test. The numbers were terrible, 70%, 55%, 65% , 5%.
They wanted to start tearing the car apart to remove the head and find the problem.
My question is with numbers this bad, would the car run at all? Is it possible that the guy did the test incorrectly?
Old Dec 17, 2014 | 04:22 AM
MM3Kwolik's Avatar
Very possible.
I've seen even worse numbers on a motor that is still running. I would imagine you have many burnt valves and guides out of spec. If I can offer one piece of advice, stay away from the dealer. Contact someone like myself or Billman if he's closer to you and either one of us can have you fixed up correctly and not at dealer pricing.
It is very common for Drive By Wire S2000's (06+) to have tight exhaust valves causing them to burn, SO CHECK YOUR VALVES GUYS!
Old Dec 17, 2014 | 06:22 AM
Reckon's Avatar
Can't go wrong with Jordan or Billman! I've had Jordan do a compression test, leakdown test and a shakedown of my S with great results. He is going to be installing a new clutch, PP and flywheel for me soon in preparation for my supercharger build. Two huge thumbs up for him working on your car!!!!
Old Dec 17, 2014 | 04:34 PM
99SH's Avatar
Those look similar to mine about 4 weeks go. I'm at 144k and the headgasket is leaking; but the vehicle ran fine.
After removing the head I discovered the exhaust valve seats were toast, as were the guides. I can attribute the bulk of the leak seeping thru the valve seats.
Old Dec 17, 2014 | 07:33 PM
TacomaDude's Avatar
OK, it actually could be over tightened valves the got me worn valve seats. Since I live in the great northwest, AKA Seattle, where should I be taking it if not the dealer?
Old Dec 17, 2014 | 10:03 PM
05thumper's Avatar
Contact s2000Junky he'll point you in the right direction. Tell him Tom sent you his way.
Old Dec 18, 2014 | 08:10 AM
jkelley's Avatar
I don't know what side of Canada Joey (JFUSION) is on but maybe he's close?
RHDS2K
May 1, 2014 09:24 AM
Bullwings
Dec 6, 2010 08:23 AM
slipstream444
May 22, 2008 04:44 PM
