Rear axle nut: ?what size socket and ? undo locking tab
Old Jan 7, 2003 | 08:50 PM
sfphinkterMC's Avatar
Default Rear axle nut: ?what size socket and ? undo locking tab
what size socket is the lock nut on the rear axle?
also, what's the correct way to lift the locking tab
is the correct torque 181 ft-lb.....i've seen 225 ft-lb in a post.
Old Jan 8, 2003 | 04:16 AM
Slows2k's Avatar
36mm. I have never bothered to undo the tab- I ust take them off with an impact wrench. Never damaged an axle by doing so. Sorry, I don't know the correct torque.
Old Jan 8, 2003 | 06:05 AM
thanks, do you re-use the nut and re-stake the tab with a drift?
Old Jan 8, 2003 | 04:33 PM
Slows2k's Avatar
No, It's not reccomended to reuse any stake nut. It's actually a poor locking device, But that's what Honda and most every other manufacturer uses.
Old Jan 8, 2003 | 05:11 PM
Prolene's Avatar
181 ft-lb is the torque settng in the Service Manual.
Old Jan 8, 2003 | 11:43 PM
vapors2k's Avatar
wasn't there some sort of service bulletien on tighting the axle nut to a higher torque spec?
Old Jan 9, 2003 | 01:03 AM
jerrypeterson's Avatar
No it was just a consensus for the guys with squeaks.
Old Jan 9, 2003 | 10:51 AM
Gernby's Avatar
Former Sponsor
These was something issued by Honda about increasing the torque on them (Here).
Old Jan 9, 2003 | 11:47 AM
thanks,
i'm going to get new bolts and torque them to 220
what kind of grease or oil do you use on them?
Old Jan 9, 2003 | 12:06 PM
Prolene's Avatar
Please post socket size and part number when you get a chance.
Honda has its own grease (urea type) that is recommended for its clutch replacement; it probably can be used in this application as well.
