Rear Axle replacement
Old Jul 3, 2015 | 12:47 PM
Slammed_s2k's Avatar
Default Rear Axle replacement
Does anyone have a link that I could follow when replacing my axle or does anyone have any tips going about this.
Old Jul 6, 2015 | 10:54 AM
eb597x's Avatar
Its actually way easier than you might think.
1) Un-stake axle nut
2) Break axle nut loose w/ vehicle on floor (easier) and recommend using 3/4in. breaker bar.
3) Safely jack up the vehicle
4) Jack up vehicle and remove wheel
5) Unbolt lower ball joint
6) Unbolt ABS sensor
7) Remove Axle nut
8) Slide spindle off the axle nut
9) Remove 6 14mm bolts/ nuts
10) Slide off and slide new one on.
To reassemble do everything in reverse.
Old Jul 9, 2015 | 07:47 PM
99SH's Avatar
Make sure you follow the torque procedure posted by Billman for the axle nut.
solitarycheese
May 26, 2017 11:10 AM
p0staboy
Oct 11, 2012 12:06 PM
jert534
Aug 9, 2006 08:19 PM
freddy33
May 21, 2006 12:00 AM
